New state timestamp State.last_reported
The State
object is now always updated and an event is always fired when an integration sets the state of an entity, regardless of any change to the state or a state attribute. This is implemented by adding a new timestamp, State.last_reported
and a new event state_reported
The state_reported
event is fired in large volume, and must be used with care to avoid detrimental effects on system load:
- Event listeners which subscribe to all events are not called when
state_reported
is fired. - It's not allowed to listen to
state_reported
events for all entities. - When listening to
state_reported
, anevent_filter
must be used to screen out events for other entities. - When listening to
state_reported
, therun_immediately
flag must be set.
Background
Home Assistant previously discarded state writes where neither the state nor the state attributes were changed, unless the integration set the force_update
flag. This behavior made it very difficult for integrations to correctly do time series analysis of numerical sensor state. It also meant the user didn't know if an integration is updating a sensor or not.
The new timestamp and associated event were discussed in architecure discussion #1062.
Custom integration impact
The following APIs have breaking changes:
- The
time_fired
argument forhass.bus.async_fire
now accepts afloat
timestamp instead of adatetime
object. - The signature of event filters which can be passed to
hass.bus.async_listen
has changed. - The
time_fired: datetime | None
argument forEvent()
has been replaced withtime_fired_timestamp: float | None
. - A new argument
last_reported: datetime
has been added toState()
in the middle of the argument list.
For more details, see core PR #113511
and core PR #113798
