Deprecating config entry listener with reloading methods in config flow
· One min read
As of Home Assistant Core 2026.6, using a config entry listener together with any reloading methods in a config flow is deprecated and will result in an error from 2026.12.
Background
Using a config entry listener together with any reloading methods in a config flow can cause the integration to reload twice and/or create a race condition.
Possible solutions
- Remove the config entry listener and rely only on the reloading methods in your config flow.
- Use
async_update_and_abort()instead ofasync_update_reload_and_abort(). - Set
reload_on_update=Falsewhen calling_abort_if_unique_id_configured().
More details can be found in the core PR.
