The naming of MQTT entities changes to correspond with HA guidelines
· One min read
The way MQTT entities are named and how device configuration can be shared between discovered entities has changed
Sharing of device configuration
Discovered MQTT entities can share device configuration, meaning one entity can include the full device configuration and other entities can link to that device by only setting mandatory fields.
The mandatory fields were previously limited to at least one of connection
and identifiers
, but has now been extended to at least one of connection
and identifiers
as well as the name
Naming of MQTT entities
Naming of MQTT entities has been changed to be aligned with the entity naming guidelines:
- The
has_entity_name
entity will be set toTrue
on all MQTT entities - Unnamed
binary_sensor
,button
,number
andsensor
entities will now be named by their device class instead of being named `MQTT binary sensor" etc. - It's now allowed to set an MQTT entity's name to
None
to mark it as the main feature of a device
