Frontend component updates in 2026.8
Component updates
ha-split-panel
We added ha-split-panel, a Home Assistant wrapper around the Web Awesome split panel component.
Use it when a Home Assistant page, dialog, or tool needs a resizable two-pane layout. Custom card authors can use Home Assistant frontend components, but internal Home Assistant UI APIs may change.
<ha-split-panel position="40" snap="50%">
<div slot="start">Editor</div>
<div slot="end">Preview</div>
</ha-split-panel>
New component-specific tokens:
--ha-split-panel-divider-width
--ha-split-panel-divider-hit-area
--ha-split-panel-min
--ha-split-panel-max
--ha-split-panel-grip-display
ha-tile-info updates
ha-tile-info gained more layout controls for custom cards and tile-like surfaces.
--ha-tile-info-gap
--ha-tile-info-min-height
--ha-tile-info-primary-min-height
--ha-tile-info-primary-line-clamp
Use --ha-tile-info-primary-line-clamp when the primary text should wrap to more than one line, and use the min-height tokens to keep rows aligned when some tiles have secondary text and others do not.
Form and selector updates
Conditional ha-form fields
ha-form schemas now support conditional field visibility with visible.
selector: { boolean: {} },
visible: { field: "advanced", value: true },
selector: { text: {} },
Supported operators are:
"eq"
"not_eq"
"in"
"not_in"
"exists"
"not_exists"
You can also combine conditions with and, or, and not.
Hidden fields are not rendered and are skipped during validation, so use visible instead of custom frontend-only hiding logic when a form field depends on another value.
Selector additions
The text selector now supports HTML pattern validation:
text: {
pattern: "[a-z0-9_]+",
validation_message: "Use lowercase letters, numbers, and underscores",
This works for both single-value and multiple-value text selectors.
Entity selectors can now filter by properties of the entity's device:
entity: {
filter: {
domain: "sensor",
device: {
manufacturer: "Home Assistant",
model: "Connect ZBT-1",
A new ui_clock_date_format selector was also added for the clock card date format editor.
Lovelace updates
state_color is moving to color
The entities and glance cards now support color as the replacement for state_color.
Before:
type: entities
state_color: true
entities:
- light.kitchen
After:
type: entities
color: state
entities:
- light.kitchen
Use color: state for the old state_color: true behavior, and color: none for state_color: false.
Custom panels and apps
Safe-area handling
Custom panels and add-on app iframes now get safe-area padding by default, so content stays clear of notches, status bars, and home indicators.
Custom panels that already handle safe areas themselves can opt out:
panel_custom:
- name: my-panel
module_url: /local/my-panel.js
handle_safe_area: true
For iframe-based custom panels, Home Assistant forwards the resolved safe-area values into the iframe document as CSS variables:
--safe-area-inset-top
--safe-area-inset-right
--safe-area-inset-bottom
--safe-area-inset-left
Add-on app iframes can also opt into managing the safe area themselves when subscribing to Home Assistant properties:
window.parent.postMessage(
type: "home-assistant/subscribe-properties",
handleSafeArea: true,
The properties message then includes safeAreaInsets.
Context and editor infrastructure
Global dirty state
DirtyStateProviderMixin now also publishes a global dirty state.
When any connected dirty-state provider has unsaved changes, window.isDirtyState is set and Home Assistant fires a dirty-state-changed event.
window.addEventListener("dirty-state-changed", (ev) => {
console.log(ev.detail.isDirty);
This is useful for shared infrastructure that needs to avoid disrupting active editors or dialogs with unsaved changes.
