MQTT publish API supports message expiry interval
· One min read
The MQTT publish API now supports setting a message expiry interval. Previously, retained messages were stored by the broker until they were replaced or explicitly cleared. With a message_expiry_interval set (in seconds), a published message — including a retained one — will automatically expire after the specified interval. This option is only supported when using MQTT protocol version 5; it is ignored when using earlier protocol versions.
The new API signatures are:
def publish(
hass: HomeAssistant,
topic: str,
payload: PublishPayloadType,
qos: int = 0,
retain: bool = False,
encoding: str | None = DEFAULT_ENCODING,
message_expiry_interval: int | None = None,
) -> None:
"""Publish message to a MQTT topic."""
and
async def async_publish(
topic: str,
qos: int = 0,
) -> None:
