OAuth2 error handling moved into the helper
· 2 min read
As of Home Assistant Core 2026.10, the OAuth2 helper raises exceptions that config entry setup already understands, so integrations no longer translate OAuth2 failures themselves.
What changed​
The OAuth2 exceptions now inherit from the config entry exception that describes what should happen, and carry a translated message from the homeassistant integration.
ExceptionAlso aResult when uncaught
ImplementationUnavailableErrorConfigEntryNotReadySetup is retried
UnknownImplementationErrorConfigEntryAuthFailedReauth flow starts
OAuth2TokenRequestErrorConfigEntryNotReadySetup is retried
OAuth2TokenRequestTransientErrorConfigEntryNotReadySetup is retried
OAuth2TokenRequestConnectionErrorConfigEntryNotReadySetup is retried
OAuth2TokenRequestReauthErrorConfigEntryAuthFailedReauth flow starts
All of them are importable from homeassistant.exceptions and carry a translated user-facing message, so the integration does not need a strings.json entry for them.
Migration​
- try:
- implementation = await async_get_config_entry_implementation(hass, entry)
- except ImplementationUnavailableError as err:
- raise ConfigEntryNotReady(
- translation_domain=DOMAIN,
- translation_key="oauth2_implementation_unavailable",
- ) from err
+ implementation = await async_get_config_entry_implementation(hass, entry)
Also remove the now-unused oauth2_implementation_unavailable entry from the exceptions section of strings.json.
Catching ValueError around this call can go as well. UnknownImplementationError subclasses ValueError for backwards compatibility, so a ValueError handler silently downgrades it and discards the translated message.
Token requests​
- try:
- await auth.async_get_access_token()
- except OAuth2TokenRequestReauthError as err:
- raise ConfigEntryAuthFailed from err
- except OAuth2TokenRequestError as err:
- raise ConfigEntryNotReady from err
+ await auth.async_get_access_token()
The same applies to await session.async_ensure_token_valid().
Quality scale​
The test-before-setup rule accepts await session.async_ensure_token_valid() in async_setup_entry as satisfying the rule, alongside await coordinator.async_config_entry_first_refresh(). Both raise the appropriate config entry exception on the integration's behalf.
When to keep catching​
Central handling is a default, not a restriction. Keep an explicit handler when the integration genuinely needs different behavior, for example:
  • Treating a specific status as permanent with ConfigEntryError instead of retrying.
  • Adding context to the message that only the integration knows.
  • Cleaning up integration state before the exception propagates.
In those cases, catch the most specific exception that applies and let the rest propagate.
