Sensor entity can now do rounding of numerical values
· 2 min read
Note: The changes described here have been reverted and replaced with rounding for presentation, more details can be found in this blog post.
SensorEntity
can now do rounding of a numerical native_value
when it's converted to the sensor state. This is implemented as a part of core PR #86074. The rounding is opt-in by integrations setting the native_precision
property. It is recommended that this property is set by integrations because it ensures the number of decimals is reasonable also after unit conversion.
A summary of the changes, copied from the PR description:
- By default, no rounding is done
- Integrations can influence the state precision by setting a new property
native_precision
- The state precision is influenced by unit conversion
- Converting from a smaller to a larger unit increases the display precision
- Converting from a larger to a smaller unit decreases the display precision if the integration has set
native_precision
- Minimum precision when converting from a larger to a smaller unit is 0, i.e. there's no rounding to tens, hundreds etc.
- User can override the display precision from the frontend
- There's no minimum precision, i.e. rounding to tens, hundreds, etc. is possible by setting a negative precision
- Integrations are encouraged to drop rounding for display and instead set property
native_precision
- Trailing zeroes are added to the sensor state's string representation to match the precision if:
- The precision is set by user
- The
native_precision
property is notNone
- Unit conversion is done
