Presenting your addon
If you choose to make your add-on available to the public, providing clear information, graphics and security reassurances will help attract users. The recommendations below are a guideline for presenting your add-on.
Adding intro
This shows in the add-on store and gives the user a short description of what the add-on can do.
This file containing the intro is usually referred to as the "README", which is generally published as the README.md file.
Adding documentation
Good documentation helps the consumer of your add-on to understand its usage, explains configuration options, points users in the right direction in the case they have questions or issues, and contains the license under which the add-on was published.
This file containing the documentation is usually referred to as the "DOCS", which is generally published as the DOCS.md file.
Add-on icon & logo
A picture is worth a thousand words. Therefore, your add-on can be improved by adding a proper image icon and logo. These images are used when showing your add-on in the Home Assistant Supervisor panel and will significantly improve the visual representation of your add-on.
Requirements for the logo of your add-on:
- The logo must be in the Portable Network Graphics format (
.png). - The filename must be
logo.png. - It is recommended to keep the logo size around 250x100px. You may choose to use a different size or aspect ratio as you see fit for your add-on.
Requirements for the icon of your add-on:
- The icon must be in the Portable Network Graphics format (
icon.png. - The aspect ratio of the icon must be 1x1 (square).
- It is recommended to use an icon size of 128x128px.
Keeping a changelog
It is likely you are going to release newer versions of your add-on in the future. In case that happens, the users of your add-on will see an upgrade notice and probably want to know what changes were made in the latest version.
A changelog is a file which contains a curated, chronologically ordered list of notable changes for each version of your add-on and is generally published as the CHANGELOG.md file.
For guidance on keeping a changelog, we recommend the keep a changelog website. They have developed a standard used by many open source projects around the world.
Offering stable and canary version
You may consider to offer a stable and a "next" or "canary" branch. These can be provided using different branches. When adding the add-on in Home Assistant, the user can select the wanted branch from a given repository by appending its name following a hashtag.
https://github.com/home-assistant/hassio-addons-example#next
You should add this information to your documentation. Also, you should consider having different names for the repositories in every branch, for example, "Super add-on (stable)" and "Super add-on (beta)".
AppArmor
In the event that an API call returns something you, as a developer were not expecting, access to too many resources could be a liability for your users. As an add-on developer, it is your responsibility to ensure your add-on will not ruin your user's machine, or perform actions that you would never expect. That's where AppArmor comes in.
While your talents in input validation, handling sensitive data and other defensive programming tactics are not being judged here, AppArmor is your add-on's second line of defense against malicious API calls, malformed settings or other forms of system hijacking.
By default, AppArmor gives you a certain level of security by restricting some general actions that are deemed inappropriate for a Docker container. You can read more about Docker's AppArmor implementation on the Docker Security page.
As for Home Assistant's implementation, you can activate your own custom AppArmor profile by putting an apparmor.txt file into your add-on folder. Adding your own apparmor.txt will load that file as the primary AppArmor profile instead of the default implementation. On top of knowing your add-on will run in a constrained and effective manner, writing your own custom apparmor.txt file will earn your add-on a security point after your add-on is installed, thus improving your user's confidence and perception of your add-on.
An apparmor.txt goes in the same folder as your config.yaml file. Below is an example apparmor.txt. Replace ADDON_SLUG with the slug defined in your add-on configuration.
apparmor.txt
#include <tunables/global>
profile ADDON_SLUG flags=(attach_disconnected,mediate_deleted) {
#include <abstractions/base>
# Capabilities
file,
signal (send) set=(kill,term,int,hup,cont),
# S6-Overlay
/init ix,
/bin/** ix,
/usr/bin/** ix,
/run/{s6,s6-rc*,service}/** ix,
/package/** ix,
/command/** ix,
/etc/services.d/** rwix,
/etc/cont-init.d/** rwix,
/etc/cont-finish.d/** rwix,
/run/{,**} rwk,
/dev/tty rw,
# Bashio
/usr/lib/bashio/** ix,
/tmp/** rwk,
# Access to options.json and other files within your addon
/data/** rw,
# Start new profile for service
/usr/bin/myprogram cx -> myprogram,
profile myprogram flags=(attach_disconnected,mediate_deleted) {
# Receive signals from S6-Overlay
signal (receive) peer=*_ADDON_SLUG,
/data/** rw,
# Access to mapped volumes specified in config.json
/share/** rw,
# Access required for service functionality
/usr/bin/myprogram r,
/bin/bash rix,
/bin/echo ix,
/etc/passwd r,
/dev/tty rw,
When working on this for your own add-ons, the following tips should help you get started:
- The S6 part of this is fairly standard. You may need to add things to accommodate your setup scripts but generally don't remove anything.
- If a service being run provides an AppArmor profile, apply that to the service. Always prefer one written by the developers.
- If there isn't one for a service and you want to make one then do the following:
a. Add minimum required access you're aware of. Things you definitely know the service needs
b. Add
complainas a flag to the profile c. Run the add-on and review the audit log withjournalctl _TRANSPORT="audit" -g 'apparmor="ALLOWED"'d. Add access as necessary until using the add-on does not generate any audit warnings e. Remove thecomplainflag so ungranted access is DENIED not ALLOWED - Repeat #3 when updating the service as new access may be required
Ingress
Ingress allows users to access the add-on web interface via the Home Assistant UI. Authentication is handled by Home Assistant, so neither the user nor the add-on developer will need to care about the security or port forwarding. Users love this feature! It connects your user directly to the add-on, can provide a seamless UX within Home Assistant and grants your add-on 2 points of security.
Here are the requirements of Ingress:
- Ingress must be enabled. Set
ingress: trueinconfig.yaml. - Your server may run on port 8099. If it does not run on 8099, you must set
ingress_port: PORT_NUMBERinconfig.yamlto match your configuration. - Only connections from
172.30.32.2must be allowed. You should deny access to all other IP addresses within your add-on server. - Users are previously authenticated via Home Assistant. Authentication is not required.
Configuration of path and port information may be queried via add-ons info API endpoint. If the Home Assistant URL is required by your addon, Ingress adds a request header X-Ingress-Path which may be filtered to obtain the base URL.
Ingress API gateway supports the following:
- HTTP/1.x
- Streaming content
- Websockets
Basic ingress example with Nginx
The following is a basic ingress implementation with an Nginx server. This contains an exampleDockerfile, config.yaml, and ingress.conf configuration.
The ingress.conf is configured to accept only connections from IP address 172.30.32.2 as we are only expecting connections from this IP address for Ingress purposes. Any other IP address will be rejected. The ingress port 8099 is utilized to reduce configuration work. If you wish to configure a different ingress port you may, but the config.yaml option ingress_port must be defined to match.
ingress.conf
server {
listen 8099;
allow 172.30.32.2;
deny all;
Our example Dockerfile is configured to support only our Nginx server and does not support a run.sh like most add-ons. You may replace the CMD with your own command to allow more configuration options while launching your add-on. This Dockerfile will RUN to install our Nginx dependencies, COPY our example ingress.conf from above to the add-on container, then CMD start Nginx.
Dockerfile
ARG BUILD_FROM
FROM $BUILD_FROM
#Add nginx and create the run folder for nginx.
RUN \
apk --no-cache add \
nginx \
&& mkdir -p /run/nginx
#Copy our conf into the nginx http.d folder.
COPY ingress.conf /etc/nginx/http.d/
#Launch nginx with debug options.
CMD [ "nginx","-g","daemon off;error_log /dev/stdout debug;" ]
In order to enable Ingress, our config.yaml file must include ingress: true and may specify the ingress_port, along with other required information.
config.yaml
version: "1.0.0"
slug: "nginx-ingress-example"
description: "Ingress testing"
arch:
- amd64
- armhf
- armv7
- i386
ingress: true
After the add-on is started, you should be able to view your Ingress server by clicking "OPEN WEB UI" within the add-on info screen.
Security
Add-on security should be a matter of pride. You should strive for the highest level of security you can possibly attain. If your add-on has a lower security rating, then users will be less likely to trust it.
Each add-on starts with a base rating of 5, on a scale of 1 to 6. Depending on decisions made during development, you will be assigned a score based on certain actions. There are some actions that have additional consequences. These additional consequences appear in the Notes section of the following table.
| Action | Change | Notes |
Use ingress: true in config.yaml | +2 | overrides auth_api rating |
Use auth_api: true in config.yaml | +1 | overridden by ingress |
| Add-on is signed with CodeNotary | +1 | |
Use custom apparmor.txt | +1 | Rating applied after installation |
Set apparmor: false in config.yaml | -1 | |
Use privileged: NET_ADMIN, SYS_ADMIN, SYS_RAWIO, SYS_PTRACE, SYS_MODULE, or DAC_READ_SEARCH, or kernel_modules: used in config.yaml | -1 | Rating applied only once if multiple are used. |
Use hassio_role: manager in config.yaml | -1 | |
Use host_network: true in config.yaml | -1 | |
Use hassio_role: admin in config.yaml | -2 | |
Use host_pid: true in config.yaml | -2 | |
Use host_uts: true and privileged: SYS_ADMIN in config.yaml | -1 | |
Use full_access: true in config.yaml | Security set to 1 | Overrides all other adjustments |
Use docker_api: true in config.yaml | Security set to 1 | Overrides all other adjustments |
