Introducing Integrations
We have finished the great migration. The result will be released as part of Home Assistant 0.92. The release has been a bit delayed because we had a lot of things to fix! With the migration done, we now consider components and platforms that share the same name to be part of the same integration. Each integration is either a single Python file, or a folder with an __init__.py. file. We have updated the documentation and introduced a new section for integrations.
Home Assistant 0.92 introduces a new manifest.json for integrations. This file, which is optional for custom components, is used by integrations to specify metadata: name, link to the documentation, dependencies, requirements and code owners. We are exploring leveraging manifest.json for additional future features, like tracking breaking changes or allowing custom components to provide config flows and being discovered.
With all these changes, we had to drop a few deprecated things and change some behavior:
- Platforms can no longer be in the directory of the entity component, like
light/my_platform.py. Instead, create a newmy_platformfolder in your custom_components, create an empty__init__.pyfile and movelight/my_platform.pytomy_platform/light.py. - Platforms can no longer have dependencies or requirements. Instead, create a
manifest.jsonin themy_platformfolder to specify them, or addREQUIREMENTSorDEPENDENCIESconstants to the__init__.pyfile. - A platform will now always require the component, if available, to be set up first.
 - It is no longer possible to provide translations for components that are contained in a single Python file. Convert them to an integration in a directory.
 - If you want to override a built-in integration, you need to specify a
manifest.jsonfor your custom integration. Note that we strongly discourage overriding built-in integrations. Instead, if you want to run an integration with custom changes change the integration name. For example if you want to run a custom version of the MQTT integration, namedmqttin Home Assistant:- Copy the content of the
mqttfolder from the Home Assistant repository to a new folder<config>/custom_components/mqtt_custom/ - Open
mqtt_custom/manifest.jsonand change the value fordomainfrommqtttomqtt_custom - Open
mqtt_custom/__init__.pyand change the value ofDOMAINfrommqtttomqtt_custom - Anywhere in your config where you referenced
mqtt, referencemqtt_custom. So usemqtt_custom:to specify the host and useplatform: mqtt_customwhen specifying platforms.
