Blocking operations with asyncio
When writing asyncio code, it's essential to ensure that all blocking operations are done in a separate thread. If blocking operations happen in the event loop, nothing else can run until the operation is complete. For this reason, no blocking operations happen in the event loop, as the entire system will stall for the duration of the blocking operation. Detailed examples of operations that might block, such as network I/O or heavy computation, are discussed below.
Be sure to enable asyncio debug mode and Home Assistant's built-in debug mode during development as many blocking I/O errors can be detected automatically.
Solving blocking I/O in the event loop
You may have reached this page because Home Assistant detected and reported a blocking call in the event loop. Beginning in version 2024.7.0, Home Assistant can detect more blocking operations in the event loop to prevent system instability. Before Home Assistant could detect these errors, they may have led to an unresponsive system or undefined behavior. Below are some tips on correcting blocking operations in the event loop.
Running blocking calls in the executor
In Home Assistant this is usually accomplished by calling await hass.async_add_executor_job. In library code, await loop.run_in_executor(None, ...) is usually used. Review Python's documentation on Running Blocking Code for tips to avoid pitfalls. Some specific calls may need different approaches.
from functools import partial
def blocking_code(some_arg: str):
def blocking_code_with_kwargs(kwarg: bool = False):
# When calling a blocking function inside Home Assistant
result = await hass.async_add_executor_job(blocking_code, "something")
result = await hass.async_add_executor_job(partial(blocking_code_with_kwargs, kwarg=True))
# When calling a blocking function in your library code
loop = asyncio.get_running_loop()
result = await loop.run_in_executor(None, blocking_code, "something")
result = await loop.run_in_executor(None, partial(blocking_code_with_kwargs, kwarg=True))
Specific function calls
Depending on the type of blocking call that was detected, the solution may be more nuanced.
open
open does blocking disk I/O and should be run in the executor with the standard methods above.
When an open call running in the event loop is fixed, all the blocking reads and writes must also be fixed to happen in the executor. Home Assistant can only detect the open call and cannot detect the blocking reads and writes, which means if the blocking read and write calls are not fixed at the same time as the open call, they will likely torment users of the integration for a long time as they will be very hard to discover.
import_module
See Importing code with asyncio
sleep
A blocking sleep should be replaced with await asyncio.sleep instead. The most common reported blocking sleep in the event loop is pyserial-asyncio which can be replaced with pyserial-asyncio-fast which does not have this issue.
putrequest
urllib does blocking I/O and should be run in the executor with the standard methods above. Consider converting the integration to use aiohttp or httpx instead.
glob
glob.glob does blocking disk I/O and should be run in the executor with the standard methods above.
iglob
glob.iglob does blocking disk I/O and should be run in the executor with the standard methods above.
walk
os.walk does blocking disk I/O and should be run in the executor with the standard methods above.
listdir
os.listdir does blocking disk I/O and should be run in the executor with the standard methods above.
scandir
os.scandir does blocking disk I/O and should be run in the executor with the standard methods above.
stat
os.stat does blocking disk I/O and should be run in the executor with the standard methods above.
write_bytes
pathlib.Path.write_bytes does blocking disk I/O and should be run in the executor with the standard methods above.
write_text
pathlib.Path.write_text does blocking disk I/O and should be run in the executor with the standard methods above.
read_bytes
pathlib.Path.read_bytes does blocking disk I/O and should be run in the executor with the standard methods above.
read_text
pathlib.Path.read_text does blocking disk I/O and should be run in the executor with the standard methods above.
load_default_certs
SSLContext.load_default_certs does blocking disk I/O to load the certificates from disk.
The following helpers ensure that the blocking I/O will happen in the executor:
aiohttp:homeassistant.helpers.aiohttp_client.async_get_clientsessionto create theaiohttp.ClientSession.httpx:homeassistant.helpers.httpx_client.get_async_clientto create thehttpx.AsyncClient.- Generic SSL:
homeassistant.util.ssl
load_verify_locations
See SSLContext.load_default_certs
load_cert_chain
