Importing code with asyncio
Determining when it is safe to import code when using asyncio can be tricky because two constraints need to be considered:
Module level imports
If your imports are at the module level (also called top-level imports) and all the necessary modules are imported in __init__.py, Home Assistant will load your integration either before the event loop starts or in a background thread using the import executor.
In this scenario, your imports are generally handled safely, so you don’t need to worry about whether they’re event-loop safe.
Imports outside of module level
If your imports are not happening at module level, you must carefully consider each import, as the import machinery has to read the module from disk which does blocking I/O. If possible, it's usually best to change to a module level import, as it avoids much complexity and the risk of mistakes. Importing modules is both CPU-intensive and involves blocking I/O, so it is crucial to ensure these operations are executed in the executor.
If you can be sure that the modules have already been imported, using a bare import statement is safe since Python will not load the modules again.
If the integration will always use the module, it's usually best to include a module-level import in __init__.py to ensure the module is loaded. However, if this creates a circular import, one of the solutions below will need to be used instead.
If the module is only used conditionally, and will only ever be imported in a single place, the standard executor calls can be used:
If the same module may be imported concurrently in different parts of the application, use the thread-safe homeassistant.helpers.importlib.import_module helper.
If it's possible the module may be imported from multiple different paths, use async_import_module: Example:
from homeassistant.helpers.importlib import async_import_module
platform = await async_import_module(hass, f"homeassistant.components.homeassistant.triggers.{platform_name}")
Determining if a module is already loaded
If you are unsure if a module is already loaded, you can check if the module is already in sys.modules. You should know that the module will appear in sys.modules as soon as it begins loading, and cpython imports are not thread-safe. For this reason, it's important to consider race conditions when code may be imported from multiple paths.
Avoiding imports that are only used for type-checking
If an imported module is only used for type checking, it is recommended to guard it with an if TYPE_CHECKING: block to avoid it being imported at runtime.
from typing import TYPE_CHECKING
if TYPE_CHECKING:
from some_module import SomeClass # Only imported for type checking
def some_function() -> SomeClass:
# Function implementation
pass
Avoid importing code that is rarely used
Importing modules can be both CPU and I/O intensive, so it’s important to avoid importing code that will rarely be used. While importing code outside the module level does add some runtime overhead, this approach is often more efficient when the code is only needed occasionally. By deferring imports, you ensure that resources are only used when necessary, reducing unnecessary processing and improving overall performance.
