Thread safety with asyncio
Developing with asyncio requires careful attention to thread safety, as nearly all asyncio objects are not thread-safe. If you are just getting started with asyncio, review Python's documentation on Developing with asyncio for tips to avoid pitfalls.
Home Assistant has some conventions for handling async and non-async code in the same code base. The top highlights are:
- Deciding how to run a function from a helper depends on whether it is decorated with
@callback
to indicate it will not block and is safe to run in the event loop; for more details, see Working with Async. - Most APIs have a sync and async version when calling a function from a thread. The async APIs are prefixed with
async_
. For example, when firing an event from a thread other than the event loop, usehass.bus.fire
instead ofhass.bus.async_fire
Be sure to enable asyncio
debug mode and Home Assistant's built-in debug mode during development as many thread safety errors can be detected automatically.
Solving thread safety errors
You may have reached this page because Home Assistant detected and reported a thread safety error. Beginning in version 2024.5.0, Home Assistant can detect, report, and block some non-thread-safe operations to prevent system instability. Before Home Assistant could detect these errors, they may have led to unexpected restarts or undefined behaviors, as they can corrupt the internal asyncio state. Below are some tips on how to correct non-threaded operations.
Ensuring code is run in the correct thread
Built-in helpers that take a callback
When using Home Assistant's built-in helpers such as event.async_track_state_change_event
or event.track_state_change_event
, it's important to call the correct API based on which thread the code runs in. If the code runs in a thread other than the event loop, use the non-async
version.
In the below example, everything will run in the event loop thread, and when async_track_state_change_event
fires,
async_update_event_state_callback
will also be run in the event loop thread because it is decorated with @callback
. If the @callback
decorator is missing, async_update_event_state_callback
would be run in the executor, which would make a non-thread-safe call to async_write_ha_state
async def async_added_to_hass(self) -> None:
"""Entity has been added to hass."""
self.async_on_remove(
async_track_state_change_event(
self.hass,
["light.other"],
self.async_update_event_state_callback,
@callback
def async_update_event_state_callback(self, event: Event[EventStateChangedData]) -> None:
"""Call when entity state changes."""
new_state = event.data["new_state"]
if new_state is None or new_state.state in (STATE_UNAVAILABLE, STATE_UNKNOWN):
return
self.async_write_ha_state()
Specific API calls
You may find you need to call one of the async API calls from a thread other than the event loop thread. In most cases, hass.add_job
can safely call an async API from another thread. Some helpers have specific sync APIs to use when calling from another thread. Below is a list of the most commonly called async APIs and the method to call them from another thread.
hass.async_create_task
When creating a task from a thread other than the event loop thread, instead use hass.create_task
hass.bus.async_fire
When firing an event from a thread other than the event loop thread, instead use hass.bus.fire
hass.services.async_register
When registering a service from a thread other than the event loop thread, instead use hass.services.register
hass.services.async_remove
When removing a service from a thread other than the event loop thread, instead use hass.services.remove
When writing the state of an entity from a thread other than the event loop thread, instead use self.schedule_update_ha_state
hass.config_entries.async_update_entry
Updating config entry must be done in the event loop thread. There is no sync API to update config entries. If it is not a mistake that the calling function is running in another thread, use hass.add_job
to schedule a function in the event loop that calls hass.config_entries.async_update_entry
async_dispatcher_send
When calling the dispatcher from a thread other than the event loop thread, instead use dispatcher_send
async_render_to_info
Templates must be rendered in the event loop thread. There is no sync API to render templates. Use hass.add_job
to schedule a function in the event loop that calls async_render_to_info
area_registry.async_create
The area registry must be modified in the event loop thread. There is no sync API for the area registry. Use hass.add_job
to schedule a function in the event loop that calls area_registry.async_create
area_registry.async_delete
to schedule a function in the event loop that calls area_registry.async_delete
area_registry.async_update
to schedule a function in the event loop that calls area_registry.async_update
category_registry.async_create
The category registry must be modified in the event loop thread. There is no sync API for the category registry. Use hass.add_job
to schedule a function in the event loop that calls category_registry.async_create
category_registry.async_delete
to schedule a function in the event loop that calls category_registry.async_delete
category_registry.async_update
to schedule a function in the event loop that calls category_registry.async_update
device_registry.async_update_device
The device registry must be modified in the event loop thread. There is no sync API for the device registry. Use hass.add_job
to schedule a function in the event loop that calls device_registry.async_update_device
device_registry.async_remove_device
to schedule a function in the event loop that calls device_registry.async_remove_device
entity_registry.async_get_or_create
The entity registry must be modified in the event loop thread. There is no sync API for the entity registry. Use hass.add_job
to schedule a function in the event loop that calls entity_registry.async_get_or_create
entity_registry.async_remove
to schedule a function in the event loop that calls entity_registry.async_remove
entity_registry.async_update_entity
to schedule a function in the event loop that calls entity_registry.async_update_entity
floor_registry.async_create
The floor registry must be modified in the event loop thread. There is no sync API for the floor registry. Use hass.add_job
to schedule a function in the event loop that calls floor_registry.async_create
floor_registry.async_delete
to schedule a function in the event loop that calls floor_registry.async_delete
floor_registry.async_update
to schedule a function in the event loop that calls floor_registry.async_update
issue_registry.async_get_or_create
The issue registry must be modified in the event loop thread. Call issue_registry.create_issue
instead.
issue_registry.async_delete
The issue registry must be modified in the event loop thread. Call issue_registry.delete_issue
instead.
issue_registry.async_ignore
The issue registry must be modified in the event loop thread. There is no sync API to ignore an issue in the issue registry. Use hass.add_job
to schedule a function in the event loop that calls issue_registry.async_ignore_issue
label_registry.async_create
The label registry must be modified in the event loop thread. There is no sync API for the label registry. Use hass.add_job
to schedule a function in the event loop that calls label_registry.async_create
label_registry.async_delete
to schedule a function in the event loop that calls label_registry.async_delete
label_registry.async_update
to schedule a function in the event loop that calls label_registry.async_update
