Device conditions
We are currently exploring alternatives to device automations. Existing device automations will continue to work but new device automations won't be accepted.
Device conditions allow a user to check if a certain condition is met. Examples are is a light on or is the floor wet.
Device conditions are defined as dictionaries. These dictionaries are created by your integration and are passed to your integration to create a function that checks the condition.
Device conditions can be provided by the integration that provides the device (for example, ZHA, deCONZ) or the entity integrations that the device has entities with (for example, light, humidity sensor). An example of the latter could be to check if a light is on or the floor is wet.
If the condition requires dynamic validation that the static CONDITION_SCHEMA can't provide, it's possible to implement an async_validate_condition_config function.
async def async_validate_condition_config(hass: HomeAssistant, config: ConfigType) -> ConfigType:
"""Validate config."""
Home Assistant includes a template to get started with device conditions. To get started, run inside a development environment python3 -m script.scaffold device_condition.
The template will create a new file device_condition.py in your integration folder and a matching test file. The file contains the following functions and constants:
CONDITION_SCHEMA
This is the schema for conditions. The base schema should be extended from homeassistant.helpers.config_validation.DEVICE_CONDITION_BASE_SCHEMA.
async_get_conditions
async def async_get_conditions(
hass: HomeAssistant, device_id: str
) -> list[dict[str, str]]:
"""List device conditions for devices."""
Return a list of conditions that this device supports.
async_condition_from_config
@callback
def async_condition_from_config(
config: ConfigType, config_validation: bool
) -> condition.ConditionCheckerType:
"""Create a function to test a device condition."""
Create a condition function from a function. The condition functions should be an async-friendly callback that evaluates the condition and returns a bool.
The config_validation parameter will be used by the core to apply config validation conditionally with the defined CONDITION_SCHEMA.
