WebSocket API
Home Assistant hosts a WebSocket API at /api/websocket. This API can be used to stream information from a Home Assistant instance to any client that implements WebSockets. We maintain a JavaScript library which we use in our frontend.
Server states
- Client connects.
- Authentication phase starts.
- Server sends
auth_requiredmessage. - Client sends
authmessage. - If
authmessage correct: go to 3. - Server sends
auth_invalid. Go to 6.
- Server sends
- Send
auth_okmessage - Authentication phase ends.
- Command phase starts.
- Client can send commands.
- Server can send results of previous commands.
- Client or server disconnects session.
During the command phase, the client attaches a unique identifier to each message. The server will add this identifier to each message so that the client can link each message to its origin.
Message format
Each API message is a JSON serialized object containing a type key. After the authentication phase messages also must contain an id, an integer that the caller can use to correlate messages to responses.
Example of an auth message:
"type": "auth",
"access_token": "ABCDEFGHIJKLMNOPQ"
"id": 5,
"type":"event",
"event":{
"data":{},
"event_type":"test_event",
"time_fired":"2016-11-26T01:37:24.265429+00:00",
"origin":"LOCAL"
When a client connects to the server, the server sends out auth_required.
"type": "auth_required",
"ha_version": "2021.5.3"
The first message from the client should be an auth message. You can authorize with an access token.
"type": "auth",
"access_token": "ABCDEFGH"
If the client supplies valid authentication, the authentication phase will complete by the server sending the auth_ok message:
"type": "auth_ok",
If the data is incorrect, the server will reply with auth_invalid message and disconnect the session.
"type": "auth_invalid",
"message": "Invalid password"
Feature enablement phase
Clients that supports features that needs enabling should as their first message (with "id": 1) send a message in the form:
"id": 1,
"type": "supported_features",
"features": { coalesce_messages: 1 }
As of now the only feature supported is 'coalesce_messages' which result in messages being sent coalesced in bulk instead of individually.
Command phase
During this phase the client can give commands to the server. The server will respond to each command with a result message indicating when the command is done and if it was successful along with the context of the command.
"id": 6,
"type": "result",
"success": true,
"result": {
"context": {
"id": "326ef27d19415c60c492fe330945f954",
"parent_id": null,
"user_id": "31ddb597e03147118cf8d2f8fbea5553"
Subscribe to events
The command subscribe_events will subscribe your client to the event bus. You can either listen to all events or to a specific event type. If you want to listen to multiple event types, you will have to send multiple subscribe_events commands.
"id": 18,
"type": "subscribe_events",
// Optional
"event_type": "state_changed"
The server will respond with a result message to indicate that the subscription is active.
"id": 18,
"type": "result",
"success": true,
"result": null
For each event that matches, the server will send a message of type event. The id in the message will point at the original id of the listen_event command.
"id": 18,
"type":"event",
"event":{
"data":{
"entity_id":"light.bed_light",
"new_state":{
"last_changed":"2016-11-26T01:37:24.265390+00:00",
"state":"on",
"attributes":{
"rgb_color":[
254,
208,
0
"color_temp":380,
"supported_features":147,
"xy_color":[
0.5,
0.5
"brightness":180,
"white_value":200,
"friendly_name":"Bed Light"
"last_updated":"2016-11-26T01:37:24.265390+00:00",
"context": {
"parent_id": null,
"old_state":{
"last_changed":"2016-11-26T01:37:10.466994+00:00",
"state":"off",
"attributes":{
"last_updated":"2016-11-26T01:37:10.466994+00:00",
"context": {
"id": "e4af5b117137425e97658041a0538441",
"parent_id": null,
"event_type":"state_changed",
"origin":"LOCAL",
"context": {
"parent_id": null,
Subscribe to trigger
You can also subscribe to one or more triggers with subscribe_trigger. These are the same triggers syntax as used for automation triggers. You can define one or a list of triggers.
"id": 2,
"type": "subscribe_trigger",
"trigger": {
"platform": "state",
"entity_id": "binary_sensor.motion_occupancy",
"from": "off",
"to":"on"
As a response you get:
"id": 2,
"type": "result",
"success": true,
"result": null
For each trigger that matches, the server will send a message of type trigger. The id in the message will point at the original id of the subscribe_trigger command. Note that your variables will be different based on the used trigger.
"id": 2,
"type": "event",
"event": {
"variables": {
"trigger": {
"id": "0",
"idx": "0",
"from_state": {
"state": "off",
"attributes": {
"device_class": "motion",
"friendly_name": "motion occupancy"
"last_changed": "2022-01-09T10:30:37.585143+00:00",
"last_updated": "2022-01-09T10:33:04.388104+00:00",
"context": {
"id": "90e30ad8e6d0c218840478d3c21dd754",
"parent_id": null,
"user_id": null
"to_state": {
"state": "on",
"attributes": {
"last_changed": "2022-01-09T10:33:04.391956+00:00",
"last_updated": "2022-01-09T10:33:04.391956+00:00",
"context": {
"id": "9b263f9e4e899819a0515a97f6ddfb47",
"parent_id": null,
"user_id": null
"for": null,
"attribute": null,
"description": "state of binary_sensor.motion_occupancy"
"context": {
"parent_id": null,
"user_id": null
Unsubscribing from events
You can unsubscribe from previously created subscriptions. Pass the id of the original subscription command as value to the subscription field.
"id": 19,
"type": "unsubscribe_events",
"subscription": 18
The server will respond with a result message to indicate that unsubscribing was successful.
"id": 19,
"type": "result",
"success": true,
"result": null
Fire an event
This will fire an event on the Home Assistant event bus.
"id": 24,
"type": "fire_event",
"event_type": "mydomain_event",
// Optional
"event_data": {
"device_id": "my-device-id",
"type": "motion_detected"
The server will respond with a result message to indicate that the event was fired successful.
"id": 24,
"type": "result",
"success": true,
"result": {
"context": {
"parent_id": null,
Calling a service action
This will call a service action in Home Assistant. Right now there is no return value. The client can listen to state_changed events if it is interested in changed entities as a result of a call.
"id": 24,
"type": "call_service",
"domain": "light",
"service": "turn_on",
// Optional
"service_data": {
"color_name": "beige",
"brightness": "101"
// Optional
"target": {
"entity_id": "light.kitchen"
// Must be included for service actions that return response data
"return_response": true
The server will indicate with a message indicating that the action is done executing.
"id": 24,
"type": "result",
"success": true,
"result": {
"context": {
"parent_id": null,
"response": null
The result of the call will always include a response to account for service actions that support responses. When an action that doesn't support responses is called, the value of response will be null.
Fetching states
This will get a dump of all the current states in Home Assistant.
"id": 19,
"type": "get_states"
The server will respond with a result message containing the states.
"id": 19,
"type": "result",
"success": true,
"result": [ ... ]
Fetching config
This will get a dump of the current config in Home Assistant.
"id": 19,
"type": "get_config"
The server will respond with a result message containing the config.
"id": 19,
"type": "result",
"success": true,
"result": { ... }
Fetching service actions
This will get a dump of the current service actions in Home Assistant.
"id": 19,
"type": "get_services"
The server will respond with a result message containing the service actions.
"id": 19,
"type": "result",
"success": true,
"result": { ... }
Fetching panels
This will get a dump of the current registered panels in Home Assistant.
"id": 19,
"type": "get_panels"
The server will respond with a result message containing the current registered panels.
"id": 19,
"type": "result",
"success": true,
"result": [ ... ]
Pings and pongs
The API supports receiving a ping from the client and returning a pong. This serves as a heartbeat to ensure the connection is still alive:
"id": 19,
"type": "ping"
The server must send a pong back as quickly as possible, if the connection is still active:
"id": 19,
"type": "pong"
Validate config
This command allows you to validate triggers, conditions and action configurations. The keys trigger, condition and action will be validated as if part of an automation (so a list of triggers/conditions/actions is also allowed). All fields are optional and the result will only contain keys that were passed in.
"id": 19,
"type": "validate_config",
"trigger": ...,
"condition": ...,
"action": ...
The server will respond with the validation results. Only fields will be included in the response that were also included in the command message.
"id": 19,
"type": "result",
"success": true,
"result": {
"trigger": {"valid": true, "error": null},
"condition": {"valid": false, "error": "Invalid condition specified for data[0]"},
"action": {"valid": true, "error": null}
Extract from target
This command allows you to extract entities, devices, and areas from one or multiple targets.
"id": 19,
"type": "extract_from_target",
"target": {
"entity_id": ["group.kitchen"],
"device_id": ["device_abc123"],
"area_id": ["kitchen"],
"label_id": ["smart_lights"]
// Optional: expand group entities to their members (default: false)
"expand_group": true
The target parameter follows the same structure as service call targets.
The server will respond with the information extracted from the target:
"id": 19,
"type": "result",
"success": true,
"result": {
"referenced_entities": ["light.kitchen", "switch.kitchen", "light.living_room", "switch.bedroom"],
"referenced_devices": ["device_abc123", "device_def456"],
"referenced_areas": ["kitchen", "living_room"],
"missing_devices": [],
"missing_areas": [],
"missing_floors": [],
"missing_labels": []
The response includes:
referenced_entities: All entity IDs that would be targeted (includes entities from devices/areas/labels)referenced_devices: All device IDs that were referencedreferenced_areas: All area IDs that were referencedmissing_devices: Device IDs that don't existmissing_areas: Area IDs that don't existmissing_floors: Floor IDs that don't existmissing_labels: Label IDs that don't exist
When expand_group is set to true, group entities will be expanded to include their member entities instead of the group entity itself.
Get triggers/conditions/services for target
The get_triggers_for_target, get_conditions_for_target, and get_services_for_target commands allow you to get all applicable triggers, conditions, and services for entities of a given target. The three commands share the same input and output format.
"id": 20,
"type": "get_triggers_for_target",
"target": {
"entity_id": ["light.kitchen", "light.living_room"],
"area_id": ["bedroom"],
// Optional: expand group entities to their members (default: true)
The server will respond with a set of trigger/condition/service identifiers that are applicable to any of the entities of the target, in the format domain.trigger_name:
"id": 20,
"type": "result",
"success": true,
"result": [
"homeassistant.event",
"homeassistant.state",
"light.turned_on",
"light.turned_off",
"light.toggle"
When expand_group is set to true (default), group entities will be expanded to include their member entities, and triggers applicable to any member will be included in the results. Otherwise, only triggers applicable to the group entities themselves will be included.
Get Entity Registry entries for display
config/entity_registry/list_for_display returns a lightweight, optimized list of entity registry entries suitable for display in the UI. Only enabled (non-disabled) entities are included.
The response contains entity data in a compact format using short property keys to minimize bandwidth and improve performance.
Use Cases
This endpoint is designed for:
- Displaying lists of entities in the UI
- Real-time entity updates for dashboard and UI components
- Bandwidth-efficient data transfer for mobile clients
- Rendering entity information in device management interfaces
Request
"id": 1,
"type": "config/entity_registry/list_for_display"
Response
"id": 1,
"type": "result",
"success": true,
"result": {
"entity_categories": {
0: "config",
1: "diagnostic"
"entities": [
"ei": "light.living_room",
"pl": "hue",
"ai": "living_room",
"di": "abc123def456",
"en": "Living Room",
"hn": true
"ei": "switch.setting",
"pl": "esphome",
"di": "cde83923",
"en": "Setting for something",
"hn": true,
"ec": 0
Response Properties
Root Object
| Name | Type | Description |
id | int | Echo of the request ID |
type | string | Always "result" |
success | boolean | Always true for successful responses |
result | object | The actual response data containing entity_categories and entities |
Entity Categories Mapping
entity_categories | object[number, string] | Maps numeric indices to entity category strings for decoding the ec property in entities. Allows the UI to interpret category indices back to human-readable names. |
Entities
Filtering and Behavior
- Disabled Entities Excluded: Only entities with
disabled_by = nullare included. Disabled entities (by user, integration, device, config entry, or system) are filtered out. - Property Abbreviation: Property keys are abbreviated to minimize JSON payload size for better performance.
- Type Conversion: Sets (like
labels) are converted to lists for JSON serialization. - Category Encoding: Entity categories are sent as numeric indices rather than strings to reduce data size. Use the
entity_categoriesmapping to decode them on the UI. - Conditional Properties: Optional properties are only included in the response if they have meaningful values (non-null, non-empty, or true).
Entity Properties
Each entity object in the entities array uses abbreviated property names for performance:
| Name | Type | Required | Description | Source |
ei | string | Yes | Entity ID - unique identifier for the entity (for example, "light.living_room") | RegistryEntry.entity_id |
pl | string | Yes | Platform - the integration that created this entity (for example, "hue", "mqtt") | RegistryEntry.platform |
ai | string | No | Area ID - the area this entity is assigned to | RegistryEntry.area_id (only if not null) |
lb | array[string] | No | Labels - list of label id's assigned to this entity for organization | RegistryEntry.labels (converted to list, only if not empty) |
di | string | No | Device ID - the device this entity belongs to | RegistryEntry.device_id (only if not null) |
ic | string | No | Icon - custom icon set by the user (overrides state icon, so if this is set, don't use the attribute value in the state) icons are in the format "prefix:icon-name", for example: "mdi:lightbulb-on" | RegistryEntry.icon (only if not null) |
tk | string | No | Translation Key - key used for translating entity name from the integration | RegistryEntry.translation_key (only if not null) |
ec | integer | No | Entity Category (index) - numeric index into the entity_categories mapping | RegistryEntry.entity_category (only if not null) |
hb | boolean | No | Hidden By - present (true) if entity is hidden by user or integration | RegistryEntry.hidden_by (only present as true if not null) |
hn | boolean | No | Has Entity Name - present (true) if entity uses the integration-provided name | RegistryEntry.has_entity_name (only present as true if true) |
en | string | No | Entity Name - display name for the entity (prioritizes user customization) | User-set RegistryEntry.name or falls back to RegistryEntry.original_name (only if either is set) |
dp | integer | No | Display Precision - sensor-specific precision for displaying values. The user-configured display_precision takes priority; falls back to the integration-provided suggested_display_precision | RegistryEntry.options["sensor"]["display_precision"] (preferred) or RegistryEntry.options["sensor"]["suggested_display_precision"] (sensor domain only, only if set) |
Manage exposed entities
These commands manage which entities are exposed to voice assistants (conversation for Assist, cloud.alexa for Alexa, cloud.google_assistant for Google Assistant).
List exposed entities
Returns the exposure status of all entities across all assistants.
"id": 18,
"type": "homeassistant/expose_entity/list"
The server will respond with a mapping of entity IDs to their exposure status per assistant:
"id": 18,
"type": "result",
"success": true,
"result": {
"exposed_entities": {
"light.living_room": {
"conversation": true,
"cloud.alexa": false,
"cloud.google_assistant": false
"sensor.temperature": {
Only entities that have been explicitly exposed or unexposed will appear in the result. Entities not present in the response have not been configured and use the default exposure setting.
Expose or unexpose entities
Expose or unexpose one or more entities to one or more voice assistants. Changes take effect immediately without requiring a Home Assistant restart.
"id": 19,
"type": "homeassistant/expose_entity",
"assistants": ["conversation"],
"entity_ids": ["light.living_room", "sensor.temperature"],
"should_expose": true
| Field | Type | Description |
assistants | array[string] | List of assistant identifiers: "conversation", "cloud.alexa", "cloud.google_assistant" |
entity_ids | array[string] | List of entity IDs to expose or unexpose |
should_expose | boolean | true to expose, false to unexpose |
The server will respond with a result message:
"id": 19,
"type": "result",
"success": true,
"result": null
Error handling
If an error occurs, the success key in the result message will be set to false. It will contain an error key containing an object with two keys: code and message.
"id": 12,
"type":"result",
"success": false,
"error": {
"code": "invalid_format",
"message": "Message incorrectly formatted: expected str for dictionary value @ data['event_type']. Got 100"
Error handling during service action calls and translations
The JSON below shows an example of an error response. If HomeAssistantError error (or a subclass of HomeAssistantError) is handled, translation information, if set, will be added to the response.
When handling ServiceValidationError (service_validation_error) a stack trace is printed to the logs at debug level only.
"id": 24,
"type":"result",
"success": false,
"error": {
"code": "service_validation_error",
"message": "Option 'custom' is not a supported mode.",
"translation_key": "unsupported_mode",
"translation_domain": "kitchen_sink",
"translation_placeholders": {
"mode": "custom"
Read more about raising exceptions or and the localization of exceptions.
