Multi-factor authentication modules
Multi-factor Authentication Modules are used in conjunction with Authentication Provider to provide a fully configurable authentication framework. Each MFA module may provide one multi-factor authentication function. User can enable multiple mfa modules, but can only select one module in login process.
Defining an mfa auth module​
info
We currently only support built-in mfa auth modules. Support for custom auth modules might arrive in the future.
Multi-factor Auth modules are defined in homeassistant/auth/mfa_modules/<name of module>.py. The auth module will need to provide an implementation of the MultiFactorAuthModule class.
For an example of a fully implemented auth module, please see insecure_example.py.
Multi-factor Auth modules shall extend the following methods of MultiFactorAuthModule class.
methodRequiredDescription
@property def input_schema(self)YesReturn a schema defined the user input form.
async def async_setup_flow(self, user_id)YesReturn a SetupFlow to handle the setup workflow.
async def async_setup_user(self, user_id, setup_data)YesSet up user for use this auth module.
async def async_depose_user(self, user_id)YesRemove user information from this auth module.
async def async_is_user_setup(self, user_id)YesReturn whether user is set up.
async def async_validate(self, user_id, user_input)YesGiven a user_id and user input, return validation result.
async def async_initialize_login_mfa_step(self, user_id)NoWill be called once before display the mfa step of login flow. This is not initialization for the MFA module but the mfa step in login flow.
Setup flow​
Before user can use a multi-factor auth module, it has to be enabled or set up. All available modules will be listed in user profile page, user can enable the module he/she wants to use. A setup data entry flow will guide user finish the necessary steps.
Each MFA module need to implement a setup flow handler extends from mfa_modules.SetupFlow (if only one simple setup step need, SetupFlow can be used as well). For example for Google Authenticator (TOTP, Time-based One Time Password) module, the flow will need to be:
  • Generate a secret and store it on instance of setup flow
  • Return async_show_form with a QR code in the description (injected as base64 via description_placeholders)
  • User scans code and enters a code to verify it scanned correctly and clock in synced
  • TOTP module saved the secret along with user_id, module is enabled for user
Workflow​
Multi Factor Authentication Workflow
Configuration example​
# configuration.xml
homeassistant:
auth_providers:
- type: homeassistant
- type: legacy_api_password
auth_mfa_modules:
- type: totp
- type: insecure_example
users: [{'user_id': 'a_32_bytes_length_user_id', 'pin': '123456'}]
In this example, user will first select from homeassistant or legacy_api_password auth provider. For homeassistant auth provider, user will first input username/password, if that user enabled both totp and insecure_example, then user need select one auth module, then input Google Authenticator code or input pin code base on the selection.
tip
insecure_example is only for demo purpose, please do not use it in production.
Validation session​
Not like auth provider, auth module use session to manage the validation. After auth provider validated, mfa module will create a validation session, include an expiration time and user_id from auth provider validate result. Multi-factor auth module will not only verify the user input, but also verify the session is not expired. The validation session data is stored in your configuration directory.
