Authentication providers
Authentication providers confirm the identity of users. The user proofs their identity by going through the login flow for an auth provider. The auth provider defines the login flow and can ask the user all information this needs. This will commonly be username and password but could also include a 2FA token or other challenges.
Once an authentication provider has confirmed the identity of a user, it will pass that on to Home Assistant in the form of a Credentials object.
Defining an auth provider
info
We currently only support built-in auth providers. Support for custom auth providers might arrive in the future.
Auth providers are defined in homeassistant/auth/providers/<name of provider>.py. The auth provider module will need to provide an implementation of the AuthProvider class and LoginFlow class, it is what asks user for information and validates it base on data_entry_flow.
For an example of a fully implemented auth provider, please see insecure_example.py.
Auth providers shall extend the following methods of AuthProvider class.
methodRequiredDescription
async def async_login_flow(self)YesReturn an instance of the login flow for a user to identify itself.
async def async_get_or_create_credentials(self, flow_result)YesGiven the result of a login flow, return a credentials object. This can either be an existing one or a new one.
async def async_user_meta_for_credentials(credentials)NoCallback called Home Assistant is going to create a user from a Credentials object. Can be used to populate extra fields for the user.
Auth providers shall extend the following methods of LoginFlow class.
async def async_step_init(self, user_input=None)YesHandle the login form, see more detail in below.
async_step_init of LoginFlow
info
We may change this interface in near future.
LoginFlow extends data_entry_flow.FlowHandler. The first step of data entry flow is hard coded as init, so each flow has to implement async_step_init method. The pattern of async_step_init likes following pseudo-code:
async def async_step_init(self, user_input=None):
if user_input is None:
return self.async_show_form(
step_id="init", data_schema="some schema to construct ui form"
if is_invalid(user_input):
return self.async_show_form(step_id="init", errors=errors)
return await self.async_finish(user_input)
