Air Quality Entity
Properties
Deprecated
The Air Quality entity is deprecated and should not be used. Instead, use separate sensors for these measurements.
Integrations that still rely on the Air Quality Entity should be migrated.
caution
The Air Quality entity does not support attribute shorthand for property implementation
NameTypeDefaultDescription
particulate_matter_2_5str | int | float | NoneRequiredThe particulate matter 2.5 (<= 2.5 μm) level.
particulate_matter_10str | int | float | NoneNoneThe particulate matter 10 (<= 10 μm) level.
particulate_matter_0_1str | int | float | NoneNoneThe particulate matter 0.1 (<= 0.1 μm) level.
air_quality_indexstr | int | float | NoneNoneThe Air Quality Index (AQI).
ozonestr | int | float | NoneNoneThe O3 (ozone) level.
carbon_monoxidestr | int | float | NoneNoneThe CO (carbon monoxide) level.
carbon_dioxidestr | int | float | NoneNoneThe CO2 (carbon dioxide) level.
sulphur_dioxidestr | int | float | NoneNoneThe SO2 (sulphur dioxide) level.
nitrogen_oxidestr | int | float | NoneNoneThe N2O (nitrogen oxide) level.
nitrogen_monoxidestr | int | float | NoneNoneThe NO (nitrogen monoxide) level.
nitrogen_dioxidestr | int | float | NoneNoneThe NO2 (nitrogen dioxide) level.
Properties have to follow the units defined in the unit_system.
