Alarm Control Panel Entity
An alarm control panel entity controls an alarm. Derive a platform entity from homeassistant.components.alarm_control_panel.AlarmControlPanelEntity.
Properties
tip
NameTypeDefaultDescription
statestr | NoneRequiredOne of the states listed in the states.
code_arm_requiredboolTrueWhether the code is required for arm actions.
code_formatCodeFormat | NoneNoneOne of the states listed in the code formats section.
changed_bystr | NoneNoneLast change triggered by.
States
ValueDescription
NoneUnknown state.
disarmedThe alarm is disarmed (off).
armed_homeThe alarm is armed in home mode.
armed_awayThe alarm is armed in away mode.
armed_nightThe alarm is armed in night mode.
armed_vacationThe alarm is armed in vacation mode.
armed_custom_bypass The alarm is armed in bypass mode.
pendingThe alarm is pending (towards triggered).
armingThe alarm is arming.
disarmingThe alarm is disarming.
triggeredThe alarm is triggered.
Supported Features
Supported features are defined by using values in the AlarmControlPanelEntityFeature enum and are combined using the bitwise or (|) operator.
ConstantDescription
AlarmControlPanelEntityFeature.ARM_AWAYThe alarm supports arming in away mode.
AlarmControlPanelEntityFeature.ARM_CUSTOM_BYPASSThe alarm supports arming with a bypass.
AlarmControlPanelEntityFeature.ARM_HOMEThe alarm supports arming in home mode.
AlarmControlPanelEntityFeature.ARM_NIGHTThe alarm supports arming in night mode.
AlarmControlPanelEntityFeature.ARM_VACATIONThe alarm supports arming in vacation mode.
AlarmControlPanelEntityFeature.TRIGGERThe alarm can be triggered remotely.
Code Formats
Supported code formats are defined by using values in the CodeFormat enum.
ValueDescription
NoneNo code required.
CodeFormat.NUMBERCode is a number (Shows ten-key pad on frontend).
CodeFormat.TEXTCode is a string.
Methods
Alarm Disarm
Send disarm command.
class MyAlarm(AlarmControlPanelEntity):
# Implement one of these methods.
def alarm_disarm(self, code=None) -> None:
"""Send disarm command."""
async def async_alarm_disarm(self, code=None) -> None:
Alarm Arm Home
Send arm home command.
def alarm_arm_home(self, code=None) -> None:
"""Send arm home command."""
async def async_alarm_arm_home(self, code=None) -> None:
Alarm Arm Away
Send arm away command.
def alarm_arm_away(self, code=None) -> None:
"""Send arm away command."""
async def async_alarm_arm_away(self, code=None) -> None:
Alarm Arm Night
Send arm night command.
def alarm_arm_night(self, code=None) -> None:
"""Send arm night command."""
async def async_alarm_arm_night(self, code=None) -> None:
Alarm Arm Vacation
Send arm vacation command.
def alarm_arm_vacation(self, code=None) -> None:
"""Send arm vacation command."""
async def async_alarm_arm_vacation(self, code=None) -> None:
Alarm Trigger
Send alarm trigger command.
def alarm_trigger(self, code=None) -> None:
"""Send alarm trigger command."""
async def async_alarm_trigger(self, code=None) -> None:
Alarm Custom Bypass
Send arm custom bypass command.
def alarm_arm_custom_bypass(self, code=None) -> None:
"""Send arm custom bypass command."""
async def async_alarm_arm_custom_bypass(self, code=None) -> None:
