Light entity
A light entity controls the brightness, hue and saturation color value, white value, color temperature and effects of a light source. Derive platform entities from homeassistant.components.light.LightEntity.
Properties
| Name | Type | Default | Description |
| brightness | int | None | None | The brightness of this light between 1..255 |
| color_mode | ColorMode | None | None | The color mode of the light. The returned color mode must be present in the supported_color_modes property unless the light is rendering an effect. |
| color_temp_kelvin | int | None | None | The CT color value in K. This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.COLOR_TEMP and ignored otherwise. |
| effect | str | None | None | The current effect. Should be EFFECT_OFF if the light supports effects and no effect is currently rendered. |
| effect_list | list[str] | None | None | The list of supported effects. |
| hs_color | tuple[float, float] | None | None | The hue and saturation color value (float, float). This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.HS and ignored otherwise. |
| is_on | bool | None | None | If the light entity is on or not. |
| max_color_temp_kelvin | int | None | None | The coldest color_temp_kelvin that this light supports. |
| min_color_temp_kelvin | int | None | None | The warmest color_temp_kelvin that this light supports. |
| rgb_color | tuple[int, int, int] | None | None | The rgb color value (int, int, int). This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.RGB and ignored otherwise. |
| rgbw_color | tuple[int, int, int, int] | None | None | The rgbw color value (int, int, int, int). This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.RGBW and ignored otherwise. |
| rgbww_color | tuple[int, int, int, int, int] | None | None | The rgbww color value (int, int, int, int, int). This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.RGBWW and ignored otherwise. |
| supported_color_modes | set[ColorMode] | None | None | Flag supported color modes. |
| xy_color | tuple[float, float] | None | None | The xy color value (float, float). This property will be copied to the light's state attribute when the light's color mode is set to ColorMode.XY and ignored otherwise. |
Color modes
New integrations must implement both color_mode and supported_color_modes. If an integration is upgraded to support color mode, both color_mode and supported_color_modes should be implemented.
Supported color modes are defined by using values in the ColorMode enum.
If a light does not implement the supported_color_modes, the LightEntity will attempt deduce it based on deprecated flags in the supported_features property:
- Start with an empty set
- If
SUPPORT_COLOR_TEMPis set, addColorMode.COLOR_TEMP - If
SUPPORT_COLORis set, addColorMode.HS - If
SUPPORT_WHITE_VALUEis set, addColorMode.RGBW - If
SUPPORT_BRIGHTNESSis set and no color modes have yet been added, addColorMode.BRIGHTNESS - If no color modes have yet been added, add
ColorMode.ONOFF
If a light does not implement the color_mode, the LightEntity will attempt to deduce it based on which of the properties are set and which are None:
- If
supported_color_modesincludesColorMode.RGBWandwhite_valueandhs_colorare both not None:ColorMode.RGBW - Else if
supported_color_modesincludesColorMode.HSandhs_coloris not None:ColorMode.HS - Else if
supported_color_modesincludesColorMode.COLOR_TEMPandcolor_tempis not None:ColorMode.COLOR_TEMP - Else if
supported_color_modesincludesColorMode.BRIGHTNESSandbrightnessis not None:ColorMode.BRIGHTNESS - Else if
supported_color_modesincludesColorMode.ONOFF:ColorMode.ONOFF - Else: ColorMode.UNKNOWN
| Value | Description |
ColorMode.UNKNOWN | The light's color mode is not known. |
ColorMode.ONOFF | The light can be turned on or off. This mode must be the only supported mode if supported by the light. |
ColorMode.BRIGHTNESS | The light can be dimmed. This mode must be the only supported mode if supported by the light. |
ColorMode.COLOR_TEMP | The light can be dimmed and its color temperature is present in the state. |
ColorMode.HS | The light can be dimmed and its color can be adjusted. The light's brightness can be set using the brightness parameter and read through the brightness property. The light's color can be set using the hs_color parameter and read through the hs_color property. hs_color is an (h, s) tuple (no brightness). |
ColorMode.RGB | The light can be dimmed and its color can be adjusted. The light's brightness can be set using the brightness parameter and read through the brightness property. The light's color can be set using the rgb_color parameter and read through the rgb_color property. rgb_color is an (r, g, b) tuple (not normalized for brightness). |
ColorMode.RGBW | The light can be dimmed and its color can be adjusted. The light's brightness can be set using the brightness parameter and read through the brightness property. The light's color can be set using the rgbw_color parameter and read through the rgbw_color property. rgbw_color is an (r, g, b, w) tuple (not normalized for brightness). |
ColorMode.RGBWW | The light can be dimmed and its color can be adjusted. The light's brightness can be set using the brightness parameter and read through the brightness property. The light's color can be set using the rgbww_color parameter and read through the rgbww_color property. rgbww_color is an (r, g, b, cw, ww) tuple (not normalized for brightness). |
ColorMode.WHITE | The light can be dimmed and its color can be adjusted. In addition, the light can be set to white mode. The light's brightness can be set using the brightness parameter and read through the brightness property. The light can be set to white mode by using the white parameter with the desired brightness as value. Note that there's no white property. If both brighthness and white are present in a service action call, the white parameter will be updated with the value of brightness. If this mode is supported, the light must also support at least one of ColorMode.HS, ColorMode.RGB, ColorMode.RGBW, ColorMode.RGBWW or ColorMode.XY and must not support ColorMode.COLOR_TEMP. |
ColorMode.XY | The light can be dimmed and its color can be adjusted. The light's brightness can be set using the brightness parameter and read through the brightness property. The light's color can be set using the xy_color parameter and read through the xy_color property. xy_color is an (x, y) tuple. |
Note that in color modes ColorMode.RGB, ColorMode.RGBW and ColorMode.RGBWW there is brightness information both in the light's brightness property and in the color. As an example, if the light's brightness is 128 and the light's color is (192, 64, 32), the overall brightness of the light is: 128/255 * max(192, 64, 32)/255 = 38%.
If the light is in mode ColorMode.HS, ColorMode.RGB or ColorMode.XY, the light's state attribute will contain the light's color expressed in hs, rgb and xy color format. Note that when the light is in mode ColorMode.RGB, the hs and xy state attributes only hold the chromaticity of the rgb color as the hs and xy pairs do not hold brightness information.
If the light is in mode ColorMode.RGBW or ColorMode.RGBWW, the light's state attribute will contain the light's color expressed in hs, rgb and xy color format. The color conversion is an approximation done by adding the white channels to the color.
White color modes
There are two white color modes, ColorMode.COLOR_TEMP and ColorMode.WHITE. The difference between the two modes is that ColorMode.WHITE does not allow adjusting the color temperature whereas ColorMode.COLOR_TEMP does allow adjusting the color temperature.
A lamp with adjustable color temperature is typically implemented by at least two banks of LEDs, with different color temperature, typically one bank of warm-white LEDs and one bank of cold-white LEDs. A light with non-adjustable color temperature typically only has a single bank of white LEDs.
Color mode when rendering effects
When rendering an effect, the color_mode should be set according to the adjustments supported by the
effect. If the effect does not support any adjustments, the color_mode should be set to ColorMode.ONOFF.
If the effect allows adjusting the brightness, the color_mode should be set to ColorMode.BRIGHTNESS.
When rendering an effect, it's allowed to set the color_mode to a more restrictive mode than the color modes
indicated by the supported_color_mode property:
- A light which supports colors is allowed to set color_mode to
ColorMode.ONOFForColorMode.BRIGHTNESSwhen controlled by an effect - A light which supports brightness is allowed to set color_mode to
ColorMode.ONOFFwhen controlled by an effect
Supported features
Supported features are defined by using values in the LightEntityFeature enum
and are combined using the bitwise or (|) operator.
EFFECT | Controls the effect a light source shows |
FLASH | Controls the duration of a flash a light source shows |
TRANSITION | Controls the duration of transitions between color and effects |
Methods
Turn on light device
class MyLightEntity(LightEntity):
def turn_on(self, **kwargs):
"""Turn the device on."""
async def async_turn_on(self, **kwargs):
"""Turn device on."""
Note that there's no color_mode passed to the async_turn_on method, instead only a single color attribute is allowed.
It is guaranteed that the integration will only receive a single color attribute in a turn_oncall, which is guaranteed to be supported by the light according to the light's supported_color_modes property. To ensure this, colors in the service action call will be translated before the entity's async_turn_on method is called if the light doesn't support the corresponding color mode:
| Color type | Translation |
| color_temp | Will be removed from the service action call if not supported and translated to hs_color, rgb_color, rgbw_color, rgbww_color or xy_color if supported by the light. |
| hs_color | Will be removed from the service action call if not supported and translated to rgb_color, rgbw_color, rgbww_color or xy_color if supported by the light. |
| rgb_color | Will be removed from the service action call if not supported and translated to rgbw_color, rgbww_color, hs_color or xy_color if supported by the light. |
| rgbw_color | Will be removed from the service action call if not supported. |
| rgbww_color | Will be removed from the service action call if not supported. |
| xy_color | Will be removed from the service action call if not supported and translated to hs_color, rgb_color, rgbw_color or rgbww_color if supported by the light. |
Home Assistant includes a utility to scale brightness.
If the light supports brightness, sometimes the brightness value needs scaling:
from homeassistant.util.color import value_to_brightness
BRIGHTNESS_SCALE = (1, 1023)
@property
def brightness(self) -> Optional[int]:
"""Return the current brightness."""
return value_to_brightness(BRIGHTNESS_SCALE, self._device.brightness)
To scale the brightness to the device range:
from homeassistant.util.color import brightness_to_value
async def async_turn_on(self, **kwargs) -> None:
value_in_range = math.ceil(brightness_to_value(BRIGHTNESS_SCALE, kwargs[ATTR_BRIGHTNESS]))
Turn Off Light Device
def turn_off(self, **kwargs):
"""Turn the device off."""
async def async_turn_off(self, **kwargs):
"""Turn device off."""
