Lock Entity
A lock entity is able to be locked and unlocked. Locking and unlocking can optionally be secured with a user code. Some locks also allow for opening of latches, this may also be secured with a user code. Derive a platform entity from homeassistant.components.lock.LockEntity.
Properties
tip
NameTypeDefaultDescription
changed_bystringNoneDescribes what the last change was triggered by.
code_formatstringNoneRegex for code format or None if no code is required.
is_lockedboolNoneIndication of whether the lock is currently locked. Used to determine state.
is_lockingboolNoneIndication of whether the lock is currently locking. Used to determine state.
is_unlockingboolNoneIndication of whether the lock is currently unlocking. Used to determine state.
is_jammedboolNoneIndication of whether the lock is currently jammed. Used to determine state.
Supported Features
Supported features are defined by using values in the LockEntityFeature enum and are combined using the bitwise or (|) operator.
ValueDescription
OPENThis lock supports opening the door latch.
Methods
Lock
class MyLock(LockEntity):
def lock(self, **kwargs):
"""Lock all or specified locks. A code to lock the lock with may optionally be specified."""
async def async_lock(self, **kwargs):
Unlock
def unlock(self, **kwargs):
"""Unlock all or specified locks. A code to unlock the lock with may optionally be specified."""
async def async_unlock(self, **kwargs):
Open
Only implement this method if the flag SUPPORT_OPEN is set.
def open(self, **kwargs):
"""Open (unlatch) all or specified locks. A code to open the lock with may optionally be specified."""
async def async_open(self, **kwargs):
