Remote entity
The remote entity can represent two different types of devices:
  1. A physical device that sends commands.
  2. A virtual device in Home Assistant that sends commands to another physical device, eg a television.
Derive entity platforms from homeassistant.components.remote.RemoteEntity
Properties​
tip
NameTypeDefaultDescription
is_onbooleanNoneIf the device is currently on or off.
current_activitystrNoneReturn the current active activity.
activity_listlistNoneReturn the list of available activities.
Activity​
An activity is a predefined activity or macro that puts the remote in a specific state. For example, a "Watch TV" activity may turn on multiple devices and change the channel to a specific channel.
Supported features​
Supported features are defined by using values in the RemoteEntityFeature enum and are combined using the bitwise or (|) operator.
ValueDescription
LEARN_COMMANDEntity allows learning commands from devices.
DELETE_COMMANDEntity allows deleting commands from devices.
ACTIVITYEntity supports activities.
Methods​
Turn on command​
class MyRemote(RemoteEntity):
def turn_on(self, activity: str | None = None, **kwargs: Any) -> None:
"""Send the power on command."""
async def async_turn_on(self, activity: str | None = None, **kwargs: Any) -> None:
Turn off command​
def turn_off(self, activity: str | None = None, **kwargs: Any) -> None:
"""Send the power off command."""
async def async_turn_off(self, activity: str | None = None, **kwargs: Any) -> None:
Toggle command​
def toggle(self, activity: str | None = None, **kwargs: Any) -> None:
"""Toggle a device."""
async def async_toggle(self, activity: str | None = None, **kwargs: Any) -> None:
Send command​
def send_command(self, command: Iterable[str], **kwargs: Any) -> None:
"""Send commands to a device."""
async def async_send_command(self, command: Iterable[str], **kwargs: Any) -> None:
Learn command​
Only implement this method if the flag RemoteEntityFeature.LEARN_COMMAND is set.
def learn_command(self, **kwargs: Any) -> None:
"""Learn a command from a device."""
async def async_learn_command(self, **kwargs: Any) -> None:
Delete command​
Only implement this method if the flag RemoteEntityFeature.DELETE_COMMAND is set.
def delete_command(self, **kwargs: Any) -> None:
"""Delete a command from a device."""
async def async_delete_command(self, **kwargs: Any) -> None:
