Water Heater Entity
Properties
NameTypeDefaultDescription
min_tempfloat110°FThe minimum temperature that can be set.
max_tempfloat140°FThe maximum temperature that can be set.
temperaturefloatnoneThe current temperature in °C or °F.
operation_modestringnoneThe current operation mode.
operation_listlistnoneList of possible operation modes.
away_modestringnoneThe current status of away mode. (on, off)
The allowed operation modes are specified in the base component and implementations of the water_heater component cannot differ.
Properties have to follow the units defined in the unit_system.
States
StateDescription
STATE_ECOEnergy efficient mode, provides energy savings and fast heating.
STATE_ELECTRICElectric only mode, uses the most energy.
STATE_PERFORMANCEHigh performance mode.
STATE_HIGH_DEMANDMeet high demands when water heater is undersized.
STATE_HEAT_PUMPSlowest to heat, but uses less energy.
STATE_GASGas only mode, uses the most energy.
STATE_OFFThe water heater is off.
Methods
set_temperature or async_set_temperature
Sets the temperature the water heater should heat water to.
set_operation_modeor async_set_operation_mode
Sets the operation mode of the water heater. Must be in the operation_list.
turn_away_mode_on or async_turn_away_mode_on
Set the water heater to away mode.
turn_away_mode_off or async_turn_away_mode_off
Set the water heater back to the previous operation mode. Turn off away mode.
