Checklist for creating a component
A checklist of things to do when you're adding a new component.
Not all existing code follows the requirements in this checklist. This cannot be used as a reason to not follow them!
0. Common
- Follow our Style guidelines
- Use existing constants from
const.py- Only add new constants to
const.pyif they are widely used. Otherwise keep them on components level
1. External requirements
- Requirements have been added to
manifest.json. TheREQUIREMENTSconstant is deprecated. - Requirement version must be pinned:
"requirements": ['phue==0.8.1'] - Each requirement meets the library requirements.
2. Configuration
- Voluptuous schema present for configuration validation
- Default parameters specified in voluptuous schema, not in
setup(…) - Schema using as many generic config keys as possible from
homeassistant.const - If your component has platforms, define a
PLATFORM_SCHEMAinstead of aCONFIG_SCHEMA. - If using a
PLATFORM_SCHEMAto be used withEntityComponent, import base fromhomeassistant.helpers.config_validation - Never depend on users adding things to
customizeto configure behavior inside your component.
3. Component/platform communication
- You can share data with your platforms by leveraging
hass.data[DOMAIN]. - If the component fetches data that causes its related platform entities to update, you can notify them using the dispatcher code in
homeassistant.helpers.dispatcher.
4. Communication with devices/services
All API specific code has to be part of a third party library hosted on PyPi. Home Assistant should only interact with objects and not make direct calls to the API.
# badstatus = requests.get(url("/status"))# goodfrom phue import Bridgebridge = Bridge(...)status = bridge.status()Tutorial on publishing your own PyPI package
Other noteworthy resources for publishing python packages:
Cookiecutter Project
flit
Poetry
5. Make your pull request as small as possible
Keep a new integration to the minimum functionality needed for someone to get value out of the integration. This allows reviewers to sign off on smaller chunks of code one at a time, and lets us get your new integration/features in sooner. Pull requests containing large code dumps will not be a priority for review and may be closed.
- Limit to a single platform
- Do not add features not needed to directly support the single platform (such as custom service actions)
- Do not mix clean-ups and new features in a single pull request.
- Do not solve several issues in a single pull request.
- Do not submit pull requests that depend on other work which is still unmerged.
It may be tempting to open a large PR when "modernizing" an integration that hasn't been touched in a while to take advantage of all the latest features available. The right approach is to break the features down into independent functional changes as best you can and to submit the PRs sequentially.
One strategy for handling sequential PRs is to create a branch for the next PR off the current PR's branch, which you can then start writing code against. This strategy is advantageous if you have split up the PRs such that one is dependent on the previous one since you are working off of the code that will be in dev once the PR is merged. If you add additional commits to the current PR because of changes/review feedback, you can rebase your next PR's branch and more easily incorporate any merge conflicts. Once your current PR has been merged, squash the commits from the current PR branch in the next PR branch and then rebase on dev. Then you can submit your next PR branch for review and rinse and repeat as needed.
6. Event names
Prefix component event names with the domain name. For example, use netatmo_person instead of person for the netatmo component. Please be mindful of the data structure as documented on our Data Science portal.
7. Tests
Strongly consider adding tests for your component to minimize future regressions.
