Hass object
While developing Home Assistant you will see a variable that is everywhere: hass. This is the Home Assistant instance that will give you access to all the various parts of the system.
The hass object
The Home Assistant instance contains four objects to help you interact with the system.
| Object | Description |
hass | This is the instance of Home Assistant. Allows starting, stopping and enqueuing new jobs. |
hass.config | This is the core configuration of Home Assistant exposing location, temperature preferences and config directory path. |
hass.states | This is the StateMachine. It allows you to set states and track when they are changed. See available methods. |
hass.bus | This is the EventBus. It allows you to trigger and listen for events. See available methods. |
hass.services | This is the ServiceRegistry. It allows you to register service actions. See available methods. |
Where to find hass
Depending on what you're writing, there are different ways the hass object is made available.
Component
Passed into setup(hass, config) or async_setup(hass, config).
Platform
Passed into setup_platform(hass, config, add_entities, discovery_info=None) or async_setup_platform(hass, config, async_add_entities, discovery_info=None).
Entity
Available as self.hass once the entity has been added via the add_entities callback inside a platform.
